Forums >> Revit Structure >> Technical Support >> Roof by footprint won't work in view
Tue, Jul 6, 2010 at 6:44:22 PM | Roof by footprint won't work in view
CNMSD
Hi, I'm doing my first project in revit structure and I want to draw a simple roof sheeting over the top of the arch. underlay. I know how to create a roof type and perform the action but for some reason I keep getting this message (see attachment). FYI I have created a level right at the apex of the roof. I also have some steel cols in place.
Do I have to create a special ref plane somewhere? I wouldn't have thought so as you can adjust the slope of the roof within the 'roof by footprint' command.
I'm in a real bind here as from what I've learned, I need to create this first so I can attach all my steel roof structure to it
Thanks in advance.
Tue, Jul 6, 2010 at 7:55:47 PM | Roof by footprint won't work in view
TomDorner
4.5 Stars: 25 Votes
The dialog box says it all.  You need to have the workplane of this view set to be a level or do the command in a different view that has the level as the workplane.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Tue, Jul 6, 2010 at 10:53:00 PM | Roof by footprint won't work in view
CNMSD
Hi Tom, Problem is is that I've done all that and it still wont work. I can't do it from another view because I need to see the arch. roof plan to draw the boundary. Am I wrong in saying that to draw this roof at the right level I must use the APEX level that I have created? please see attached some more screen shots to show the chronological order I am trying to acheive this. (the level I am chosing is the 'APEX' level.
Someone please help, this is driving me bonkers.
Wed, Jul 7, 2010 at 10:48:14 AM | Roof by footprint won't work in view
TomDorner
4.5 Stars: 25 Votes
You can't create a roof by foot print in a non plan based view.  The Revit help file is pretty clear on this topic and it sounds like you need to brush up on the Revit basics via a tutorial or class.
Tom
Fri, Jul 9, 2010 at 12:10:55 AM | Roof by footprint won't work in view
CNMSD
Thanks for the response, but it was a plan based view.
I deleted the level and created a new one and then it seemed to work. The only thing I can think of is it might have been a reference view originally and then I made it one through the  plan view tab.
"Two Cut - Square" Rafter Cut won't appear with Roof by Extrusion.
Mon, Jun 5, 2017 at 10:57:14 AM
Roof - Inner loops of a footprint sketch may not have slope-defining lines.
Thu, Oct 2, 2008 at 4:20:16 PM
RAC2008 - Building footprint on Roof Plan
Wed, Aug 15, 2007 at 11:49:47 AM
How to drop one side of a revit roof from footprint ?
Thu, Jan 6, 2011 at 4:37:41 AM
Editing the footprint of a roof by extrusion?
Wed, Feb 17, 2016 at 2:02:45 PM
Page generation time: 2.6215
