Forums >> Revit Building >> Technical Support >> MATERIAL PURGE
Mon, Jul 5, 2010 at 3:26:39 AM | MATERIAL PURGE
online2000
online2000 Avatar
hi wizards,
is there a way to purge materials that are not used?
i have attached some materials to walls that i would prefer to "undo"- i realizeed that using the wall structure layers would be wiser and now i have to un-attach materials by using the paint tool...
is ther a fast way to do this?
thanks
E
eli
Mon, Jul 5, 2010 at 9:08:19 AM | MATERIAL PURGE
You can individually delete materials.
Instead of using the paint tool, just re-assign the materials in your wall definition.
Mon, Jul 5, 2010 at 9:27:58 AM | MATERIAL PURGE
online2000
online2000 Avatar
sure-
but strange that it wont purge materials as it sdoes all other families that are not used
 as i have to re-select each wall and change it back to default with paint tool- i have made many of these instance  modifications.
eli
Text style that I can't get purge
Wed, Sep 5, 2012 at 8:40:41 AM
purge selected
Wed, Sep 17, 2008 at 10:40:42 PM
Where are Regions in the Purge List
Tue, Feb 14, 2017 at 10:33:21 AM
Purge Command - possible to purge family types accidentally?
Tue, Aug 20, 2013 at 12:01:08 PM
Delete or Purge out Title Blocks?
Wed, Nov 26, 2008 at 5:06:00 PM
Page generation time: 1.7716
