Forums >> Community >> Newbies >> low wall not displaying correctly with view range
Fri, Jul 2, 2010 at 4:25:05 PM | low wall not displaying correctly with view range
jlurie
I have a 5' high wall. With the default view range, it does not display the drywall when put on fine view. If I change it to 6' high, then it does display it.  However, keeping it at 5', I cannot seem to get any combination of heights in the view range categories to make the drywall layers display.  What am I doing wrong?
Sun, Jul 4, 2010 at 8:27:01 AM | low wall not displaying correctly with view range
4 Stars: 205 Votes
Your HELP menu is a great "book", take a look...
Tue, Jul 6, 2010 at 9:49:15 AM | low wall not displaying correctly with view range
jlurie
I have spent a bunch of time looking at both the help feature, and a reference book - but that has not solved it.
I am also using phases - as this is an office demo/reno plan.
The wall are supposed to be 5', but I can only get the drywall layers to display after I increase them to 6' - which I discovered by experimenting.  After various combinations in the view range dialogue, I still cannot get this to work with the walls at 5' high.
Tue, Jul 6, 2010 at 10:01:52 AM | low wall not displaying correctly with view range
NkatOmg2
NkatOmg2 Avatar
4 Stars: 1 Votes
Try putting your Cut Plane going through the actual wall, not at the very top of the wall.  If this does not work, please post some pictures of your settings - View Range dialogue box, an Elevation of the wall with Level heights, stuff like that - so we can try to help you out.
 I use Autodesk Revit Structure 2011
 My songs: http://nkat.newgrounds.com
Thu, Jul 8, 2010 at 9:26:01 AM | low wall not displaying correctly with view range
jlurie
Here is some more info about my problem.  I also asked the teacher at my Revit class last night, but he also could not figure out why Revit is not displaying the drywall layer lines in the 5' wall but it is in the 6' wall.  Both walls are in the "new construction" phase.
Thu, Jul 8, 2010 at 9:34:37 AM | low wall not displaying correctly with view range
coreed
coreed Avatar
4 Stars: 16 Votes
did you look at what Typhoon posted?
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Jul 8, 2010 at 9:45:54 AM | low wall not displaying correctly with view range
TomDorner
4.5 Stars: 25 Votes
As Coreed stated, Typoon gave you the exact answer you needed.
Sounds like you need to get a new Revit instructor as well as this has been the behaviour of Revit from the very beginning.
It is also a reason that if you ever worked for me or took a class from me you would know that you never never model walls that have an 'unconnected' height.
If you want a 5 foot high wall to display the layers, then change the properties to:
Base Constraint: Level 1
Top Constraint: Level 1
Top Offset: 5'
See what happens?  Show that to your supposed Revit instructor and get your money back.
Edited on: Thu, Jul 8, 2010 at 9:46:59 AM
Tom
Fri, Aug 3, 2012 at 4:35:37 PM | low wall not displaying correctly with view range
clarkmd
Thanks TomDorner. That worked!
Edited on: Fri, Aug 3, 2012 at 4:41:09 PM
2015 CURVED WALLS NOT DISPLAYING IN REVIT CORRECTLY
Fri, May 6, 2016 at 9:21:20 AM
Reversed View range
Thu, Sep 6, 2007 at 4:06:31 PM
Curtain Panel Rep. in Plan not displaying correctly in Project
Fri, Feb 26, 2016 at 1:29:14 PM
Framing Plan problem with displaying
Fri, Oct 21, 2011 at 8:51:54 AM
Wall Build-up displaying incorrectly
Wed, Sep 25, 2013 at 8:39:49 AM
Page generation time: 3.3379
