Forums >> Revit Building >> Technical Support >> Baluster rendering
Fri, Jul 2, 2010 at 11:54:44 AM | Baluster rendering
Earchitect
Hi,
My first post here. I am having rendering issues with balusters in Revit 2009. regardless of the material I apply to the balusters in the project browser they will not render with that material. Rails accept material changes fine and the balusters will shade (or shade with edges) properly in the view window, but when rendered they hold a single color.
this is probably something very simple I am missing.
images attached.
TV is bubblegum for the eyes
Fri, Jul 2, 2010 at 12:15:00 PM | Baluster rendering
4 Stars: 205 Votes
That's not a "Baluster", that's a Railing, look at the images...
Fri, Jul 2, 2010 at 12:23:41 PM | Baluster rendering
Earchitect
As you have pointed out the rails - top and bottom - are rendering based on the testure i have applied - see image.
The balusters (2 different kinds in this railing) regardless of what texture i assign to them - available in the project browser - do not render.
Fri, Jul 2, 2010 at 12:25:49 PM | Baluster rendering
Earchitect
let me retry to post those images
Fri, Jul 2, 2010 at 12:30:14 PM | Baluster rendering
4 Stars: 205 Votes
Sorry, i thought you are talking about those Black rails, in the first post you have "Metal - Aluminium" in the last post you have "kawneer - Anodiz", now my question is: is this the same material (texture) in Render Appearence?
Ohhh sorry, that last picture is about Rails and not the balusters....
Edited on: Fri, Jul 2, 2010 at 12:32:35 PM
Fri, Jul 2, 2010 at 12:34:16 PM | Baluster rendering
Earchitect
I am probably not being very clear. This railing like all railings, is made up of rails (horizontal elements) and balusters (vertical elements)
The rails which render black in my first post are correct - they have a kawneer finish -
The balusters, which I want to render the same will not accept (or rather will not render) with that or any other texture I apply. I have tried just assigning the color black to them I have tried a multitude of different finishes - including the aluminum setting - no texture so far wants to render.
They do shade however.
Fri, Jul 2, 2010 at 12:39:52 PM | Baluster rendering
4 Stars: 205 Votes
They work fine with me, try to open that family and check if there are some material parameter in that baluster, check the name then in project go to materials and see what material have that same name...
Fri, Jul 2, 2010 at 12:49:51 PM | Baluster rendering
Earchitect
See attached images.
I set all the railing componants to the same material - as you can see they shade the same - the included screen from the completed render shows the problem
Fri, Jul 2, 2010 at 1:01:38 PM | Baluster rendering
4 Stars: 205 Votes
Did you open that family? did you check what is the parameter (name) of the material into the family?
Fri, Jul 2, 2010 at 1:09:50 PM | Baluster rendering
Earchitect
I assume by category is correct - I havent edited the family at all - just assigned material in the project
Fri, Jul 2, 2010 at 1:12:43 PM | Baluster rendering
#11
4 Stars: 205 Votes
No problem here.
Fri, Jul 2, 2010 at 1:14:39 PM | Baluster rendering
#12
Earchitect
sigh.
thanks for your efforts
Sat, Jul 3, 2010 at 1:37:49 PM | Baluster rendering
#13
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
try opening the family, re asign the black rendering ones, and change the name of the material. Then re-load the family into proyect, overwrite existing. Voliá.
Sun, Jul 4, 2010 at 6:02:14 PM | Baluster rendering
#14
hisdirt
5 Stars: 5 Votes
Hi there Earchitect,
If you are really wanting to get to the bottom of this, try posting your stripped down .rvt file and we can troubleshoot the rendering issues.
Otherwise try using a different render material to see if thats the problem, change the background to 'sky' instead of colour, play with the reflectivity of the surface etc.
Hope this helps!
Tue, Jul 6, 2010 at 4:10:35 PM | Baluster rendering
#15
Earchitect
My thanks to everyone for their responses and suggestions.
While I never resolved the render issue with the generic rail componants I was using, by downloading a family from a manufacturer I was able to install a rail in the model that fit my needs and rendered properly.
attached is a progress rendering of my first full Revit based project.
rail 1 and baluster heigth
Tue, Nov 8, 2011 at 10:40:22 AM
custom baluster with decorative piece not staying equal 2019
Thu, Jun 14, 2018 at 1:54:47 PM
Need help! Custom baluster
Mon, Apr 20, 2015 at 7:40:11 AM
Baluster's are rendering black??
Tue, Feb 23, 2010 at 9:08:22 AM
Baluster Family Help
Thu, Oct 16, 2014 at 11:15:48 AM
Page generation time: 3.0970
