Forums >> General Discussion >> Revit Project Management >> Autodesk Image Modeler
Thu, Jul 1, 2010 at 5:50:22 PM | Autodesk Image Modeler
jgmas
Anybody familiar with Autodesk Image Modeler?
My questions is Can you import a model from Image Modeler to Revit?
Thanks
Thu, Jul 1, 2010 at 7:00:20 PM | Autodesk Image Modeler
TomDorner
4.5 Stars: 25 Votes
Not directly to Revit. It will go to .dwg which can then be brought in as a mass family and used to build a Revit model using faces.
From the Autodesk FAQ's:
How does ImageModeler 2009 integrate with other Autodesk products?
Improved support for DWG files provides faster, more accurate export of data to other Autodesk software such as AutoCAD®. The FBX®‐based RecognizeTM scene‐loading technology enables ImageModeler users to quickly and accurately export geometry, textures, and cameras. Also, the Autodesk FBX file interchange format allows users to easily transfer assets to 3ds Max, Maya, and Autodesk® MotionBuilder® software, as well as any other content creation package that supports FBX.
What are the imports and exports can be done with ImageModeler 2009?
Here is the list of ImageModeler imports and exports.
Import:
OBJ: 3D objects and textures
Export:
FBX: 3D points and objects, textures, cameras Maya (.ma): 3D points and objects, textures, cameras OBJ: 3D objects and textures DWG: 3D points and objects, measures
Tom
www.reviteer.com   http://twitter.com/Reviteer
u-bolt creating_newbie revit modeler
Mon, Jun 18, 2018 at 10:53:55 AM
How do you make a Dutch Hip Roof with roof modeler?
Tue, Jan 17, 2006 at 2:09:26 AM
Revit w/ Autodesk Showcase
Tue, Aug 27, 2013 at 11:25:06 AM
Revit 2014 or Revit 2016 Generating a Detailed Image for a Family component
Sun, Feb 28, 2016 at 8:13:14 PM
revit export to CAD, autodesk impression import...
Tue, Jun 14, 2011 at 9:36:56 AM
Page generation time: 1.7873
