Forums >> General Discussion >> Revit Project Management >> bringing dwg files into Revit
Thu, Jul 1, 2010 at 12:58:45 PM | bringing dwg files into Revit
vanderloo
Hi,
I switched from acad architecture to Revit several years ago and recently received a half finished autocad 2007 project to finish. Been messing around with a couple different approaches to figure out which will work best. Started trying to finish in Architecture but having too many issues with error messages and plot styles.  I'm wondering if I should just edit in architecture and import to Revit for sheet setup and plotting. Would the general consensus be to import into revit as drafting views, add needed notes, dimensions, tables, etc., drag to a sheet and plot?
Thanks
Bringing ADT lines into a Revit Model
Wed, Mar 4, 2009 at 6:56:22 AM
Linked DWG Files not visable in RCP
Mon, Oct 19, 2009 at 1:46:58 PM
Bringing Sletchup models in to revit
Thu, Jan 29, 2009 at 1:10:26 PM
DWG files for deck construction
Tue, Jan 16, 2018 at 8:49:05 AM
Exporting issues... exported dwg files missing information
Thu, Jan 24, 2008 at 11:43:21 AM
Page generation time: 1.9017
