Forums >> Revit Building >> Technical Support >> Can not pick an object
Wed, Jun 30, 2010 at 1:55:00 PM | Can not pick an object
bellgroup
I'm having trouble picking a floor that I put in. Also there is a line that I drew on top of it that will not pick also. Can anyone help?
Thanking you early
Wed, Jun 30, 2010 at 3:00:07 PM | Can not pick an object
Bimman
Bimman Avatar
1 Stars: 2 Votes
did you try hovering over it and pressing tabing thru your selections? you could always cut a section thru it and select you floor that way then go back to your plan view to edit the foot print.  it should all stay selected as you go thru views.
PWD
Thu, Jul 1, 2010 at 12:25:47 PM | Can not pick an object
RevitNOOB
RevitNOOB Avatar
also check that you didnt accidently place your floor into a design option.  that will lock out all items unless you are specifically editing that option.
Wed, Jul 7, 2010 at 8:36:20 AM | Can not pick an object
bellgroup
Thanks to the both of you, it was that it was on a different design option setting. It was the first time really using the tool and it is a lesson learned. Seams the design option tool adds another level of stuff to keep up with.
why wont object pick new host?
Tue, Nov 8, 2011 at 3:23:56 PM
3d edge pick cancels previous pick.
Thu, Feb 9, 2017 at 5:32:26 PM
is there an anologue to the CAD "from" command in Revit?
Thu, Jun 28, 2012 at 9:39:14 PM
Rendering Problem.
Wed, Apr 9, 2008 at 3:08:23 PM
Embedded Detail Component and Object Styles
Fri, Feb 12, 2010 at 3:21:25 PM
Page generation time: 2.1196
