Forums >> Revit Systems >> Technical Support >> Revit Not Ploting Vertical Dimensions to Scale???
Tue, Jun 29, 2010 at 1:32:26 PM | Revit Not Ploting Vertical Dimensions to Scale???
CKorleski
Good Afternoon,
I am having a problem printing dwgs. to scale out of Revit.  I have serched and serched for answers to this question on this forum and others, still without a solution.  I have checked my title block, I have made sure that I am printing (zoom 100%) not fit to page, I have reset my print drivers, checked printer settings.  After all of this I still can't get Revit to print to scale.  But the odd thing about this is, all of my dimesions from the left to the right of the page are dead on.  But all of the dimensions from top to bottom are off by 1"-3".  This is happening in both Revit Structure 2010 and Revit MEP 2010... Any help would be great.
Tue, Jun 29, 2010 at 1:47:16 PM | Revit Not Ploting Vertical Dimensions to Scale???
CKorleski
Ok so to add to my first post, I have been playing around with some of the settings and I was able to get the sheet to print to the correct scale all around, but the only way to do this is to set the paper placment to no margin, and by doing this I now have part of my drawing printing off the page....
Ploting mass
Mon, Oct 2, 2006 at 11:25:43 AM
scale check
Tue, Oct 23, 2012 at 5:05:08 AM
Topography Scale
Fri, Nov 25, 2011 at 3:27:35 AM
How do you handle dimensioning not-to-scale stuff in Revit?
Mon, Aug 15, 2011 at 2:30:05 PM
Aligned dimensions for centering curtain wall door
Fri, Dec 23, 2011 at 6:26:40 AM
Page generation time: 1.5654
