Forums >> Revit Building >> Technical Support >> Families - How do you dimension to a cut extrusion
Wed, Mar 17, 2004 at 1:24:10 PM | Families - How do you dimension to a cut extrusion
dtm00
I am trying to make a family of exterior sliding doors that recess into a pocket. Each leaf is either 36" 42" or 48". I need the depth of the pocket to correspond to the leaf size. How do you dimension to a cut extrusion, so that I can make a parameter out of it. In addition to this, I am also trying to get the wall to resize based on the number of pockets although I think that this is too much for one family to do though, and will end up making a new file. thanks, David
Wed, Mar 17, 2004 at 6:40:01 PM | RE: Families - How do you dimension to a cut extrusion
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
so are you trying to dimension a void?
Hiroshi Jacobs
Wed, Mar 17, 2004 at 6:54:45 PM | RE: Families - How do you dimension to a cut extrusion
dtm00
I got it to work. sorry, i'm a 3 day newbie (started revit 3 days ago) and didn't know how to snap the ends of the voids to the reference planes. Then I didn't know where the cut geometry tool was. Got that too. Thanks for replying though. I am working through the families now. David
Wed, Mar 17, 2004 at 6:56:27 PM | RE: Families - How do you dimension to a cut extrusion
dtm00
On a side note, your website doesn't seem to be loading, or it is loading reaaly slow. It is pointing to 24.107.70.45, and seems to be getting nothing. Again thanks for trying to help. dtm
Thu, Mar 18, 2004 at 9:01:50 AM | RE: Families - How do you dimension to a cut extrusion
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
thanks for the heads up, I noticed that last night and I'm working on it.
Hiroshi Jacobs
Fri, Mar 19, 2004 at 8:49:04 AM | RE: Families - How do you dimension to a cut extrusion
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
Ok it should be up and working now...
Hiroshi Jacobs
re-joining (?) cut extrusion with extrusion
Tue, Apr 17, 2007 at 10:26:27 PM
Cut a void from an extrusion
Thu, Feb 19, 2015 at 1:08:44 AM
Void Won't Cut Extrusion
Wed, Feb 13, 2013 at 11:04:26 AM
Void Sweep won't cut extrusion
Fri, Aug 24, 2012 at 3:02:42 PM
Extrusion won't cut
Fri, Jun 23, 2017 at 12:42:31 PM
Page generation time: 1.3838
