Forums >> Revit Building >> Technical Support >> Duplicating views and phasing Question
Sun, Jun 27, 2010 at 2:40:03 PM | Duplicating views and phasing Question
ksmith
OK, I seem to be grasping the idea of using phasing in my drawings a little better now although only the bare basics of how the concept works.
In my current model I have phases set up for existing, demolition and new construction and everything appears as it should do so I'm happy with that.
If I decide to add lets say, another wing to my model, and wanted to show it as a complete alternative to the current proposals, am I right in saying that all I need do is follow the same procedure as before by setting up a new phase, duplicating the views, and drawing the new geometry?
So in fact, can it be said that I can set up as many phases as I want by following this same procedure, all giving me different variations of construction whilst all sheets being contained in the same model/file?
Thanks all, your help appreciated as always
Kirk
USING REVIT 2011--- This old builder is determined to Learn Revit no matter what it takes.
Mon, Jun 28, 2010 at 7:18:37 AM | Duplicating views and phasing Question
For what you want to do ...another wing alternative... you would be better off to use a design option that is in the new phase.
duplicating views without duplilcating callouts or view tags
Wed, Sep 11, 2013 at 3:09:15 PM
Duplicating Views
Wed, Jun 8, 2011 at 5:34:23 PM
views and sheets for revisions [ 1 2 ]
Fri, Mar 11, 2011 at 9:21:39 AM
20
Graphic overrides (phasing) for 3D views
Wed, Apr 30, 2014 at 2:25:42 PM
Duplicating a floor plan and Creating a new floor plan
Wed, Feb 3, 2016 at 7:28:16 AM
Page generation time: 1.9569
