Forums >> Revit Building >> Technical Support >> adding trusses
Fri, Jun 25, 2010 at 9:21:00 AM | adding trusses
jfw105
is there an easy way to add trusses to you build i cant seem to make it work.
Fri, Jun 25, 2010 at 11:53:59 AM | adding trusses
carrucha75
carrucha75 Avatar
4 Stars: 24 Votes
you do have to do it manually or system trusses there is a good pluggin for this at www.tools4revit.com
Not Sure What Revit Can Do?... Find it OUT!!!
Imagination is more important than knowledge...” -Albert Einstein
Tue, Jun 29, 2010 at 7:14:26 AM | adding trusses
latemore
latemore Avatar
3 Stars: 2 Votes
have you tried downloading the trusses from revitcity.  i put some here a while ago, as have others.  they are often 'beams' in how they work.
workflow for architectural building section showing roof trusses.
Wed, Jan 10, 2018 at 10:12:23 AM
Creating trusses
Thu, Dec 29, 2016 at 6:44:09 AM
Adding Trusses into Revit Project
Wed, Sep 21, 2005 at 2:26:18 PM
Ref Planes
Mon, Dec 5, 2005 at 7:11:44 PM
Roof Trusses
Wed, Dec 23, 2009 at 6:56:52 AM
Page generation time: 3.1111
