Forums >> Revit Building >> Technical Support >> Working with linked files
Wed, Oct 5, 2005 at 4:32:32 AM | Working with linked files
Will9000
4 Stars: 5 Votes
Hi, I have drawn 2 buildings each on a separate file. I have then linked one of the buildings onto the other. In the new drawing file, the linked building is a block and i cannot ammend anything. The only way i can ammend things is to close the file and open the existing building. Is there anyway i can change the properties / settings of the linked file so i can ammend them?? Many thanks
Wed, Oct 5, 2005 at 6:03:02 PM | RE: Working with linked files
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
No you cannot edit a linked file except for in its host file. You could start two sessions of revit and open the file in the other session so you can switch between them... (although its not recommended by the factory, however i've never had any problems with it).
Thu, Oct 6, 2005 at 8:17:08 AM | RE: Working with linked files
Will9000
4 Stars: 5 Votes
Thanks for your response, Much appreciated
autocad linked files and refresh
Tue, Apr 7, 2009 at 2:12:36 PM
Displaying in linked files
Sat, Jun 11, 2011 at 4:37:49 PM
editing linked files without having them unlinked?
Fri, Dec 4, 2009 at 10:06:44 AM
Linked CAD files are not turning off
Tue, Nov 29, 2016 at 3:31:28 PM
14
Working on Large Files
Mon, Jul 9, 2012 at 4:11:10 PM
11
Page generation time: 0.7223
