Forums >> Revit Building >> Technical Support >> creating column based with carvings
Wed, Oct 5, 2005 at 2:41:01 AM | creating column based with carvings
Shanthi
i would like to attache a carved surpace on to a circular another shape. i have attached the concern file and the reference is in autocad format. the base of the column is having two profiles which has to be extruded along with the shape of the base. So please clarify and it would be greatful for me. Thankyou
Wed, Oct 5, 2005 at 6:01:29 PM | RE: creating column based with carvings
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You create a series of reference planes to segment around the curve then set them as the work plan and extrude voids of the appropriate shape into the base of the column in order to achieve the carved recess.
How do you create a column that the proportions adjust to the height
Wed, Feb 25, 2009 at 8:54:53 AM
New column based on concrete column family
Fri, Aug 8, 2008 at 3:37:56 AM
Creating Columns
Tue, Sep 6, 2011 at 2:56:33 PM
Tagging Graphical Column Schedule
Wed, Nov 24, 2010 at 8:41:14 PM
Column Schedule
Mon, Apr 21, 2008 at 7:35:29 AM
Page generation time: 1.1844
