Forums >> Revit Systems >> Technical Support >> help with creating plenum space - MEP2011
Wed, Jun 23, 2010 at 3:37:33 PM | help with creating plenum space - MEP2011
sfountain
im attempting to create a plenum space, using a linked revit model. I created a plenum level, and set its view depth appropriately. when i create the space, for some reason it's finding the boundaries for rooms located on the floor above the plenum. Ive checked view depth properties and verified the levels in sections.
I'm not having this problem creating other spaces on other levels, so I'm not sure where the problem lies. one question though - if this project is to use a ceiling as a plenum, does the architectural model also need to have the plenum space defined as a room?
thanks
Wed, Jun 23, 2010 at 5:00:49 PM | help with creating plenum space - MEP2011
sfountain
Nevermind...found the culprit - fwiw under the type properties for the plenum level, i unchecked automatic room height computation.
Roofs and ceilings in Analytical Surfaces
Thu, Jun 2, 2011 at 11:12:47 AM
defining a space with multiple offset floors (MEP2011)
Tue, Jun 29, 2010 at 12:30:50 PM
Inner space is not surrounded by outer space with higher height.
Thu, Sep 6, 2012 at 8:34:57 AM
locking linked files in mep2011
Mon, Mar 19, 2012 at 11:16:19 PM
Creating Space Frames
Mon, Mar 24, 2008 at 3:20:47 AM
Page generation time: 0.1972
