Forums >> Revit Building >> Technical Support >> Is it possible to put room tag outside?
Wed, Jun 23, 2010 at 7:27:11 AM | Is it possible to put room tag outside?
Corleone07
Is it possible to put room tag outside the room area?
some simple tehnique ???  :o
Wed, Jun 23, 2010 at 7:51:06 AM | Is it possible to put room tag outside?
HDDWG2003
HDDWG2003 Avatar
3.5 Stars: 11 Votes
YES TURN ON THE LEADER AND DRAG THE TAG OUTSIDE THE ROOM
Thu, Jun 24, 2010 at 8:15:01 AM | Is it possible to put room tag outside?
Corleone07
Thanks! It works.
 But is it alsow possible with hidden leaders?
Wed, Jun 30, 2010 at 5:24:10 PM | Is it possible to put room tag outside?
Jackicraig
No, it gives you a warning (as I'm sure you've seen). I initially thought you might be able to hide the leader with linework or a filled region, but you cannot.
What you CAN do is move the end of the leader as far to the edge of the room as possible, minimizing its appearance.
Editing a room tag
Thu, Oct 12, 2017 at 3:17:41 PM
Room tag not showing in only one room. [ 1 2 ]
Sat, Sep 27, 2025 at 3:40:00 AM
15
Using Room Tag Family Parameters in a Celing Tag Family
Mon, Sep 22, 2008 at 7:52:40 AM
How can I add clear Height (floor to bottom of slab above) in a Room Tag?
Sun, Aug 21, 2016 at 3:08:14 AM
cant place Room tag
Mon, Oct 10, 2011 at 8:33:43 AM
Page generation time: 1.7233
