Forums >> Revit Building >> Technical Support >> Detail Componet Parameters - Revit Structure 2009
Tue, Jun 22, 2010 at 1:26:14 PM | Detail Componet Parameters - Revit Structure 2009 With Stirup Componet Attached!
mjstructures
mjstructures Avatar
I've built a 2D Striup because using the 3D rebar is way too time consuming. When you place it over a conc. section, you can snap it to the edges of the conc. because it has an offset instance parameter preset to 3 inches. If you need to tweek the offset you can grab the blue grip and drag it in or out without affecting the componate locked to the perimeter of the conc. If the beam changes in size the offset parameter keeps its offset distance from the edge BUT only for the sides. I cannot figure out why the bottom and top offsets don't move. Any thoughts?Edited on: Tue, Jun 22, 2010 at 1:35:24 PMEdited on: Tue, Jun 22, 2010 at 1:53:06 PM
Edited on: Tue, Jun 22, 2010 at 2:52:54 PM
Thu, Jun 24, 2010 at 3:47:32 PM | Detail Componet Parameters - Revit Structure 2009
mjstructures
mjstructures Avatar
Anyone? Anyone? Dee Oh Oh Economics? Anyone?
SketchUp into Revit Structure 2009
Fri, Feb 27, 2009 at 9:51:24 AM
structure model disappear in the detail plan
Tue, Jan 8, 2013 at 1:34:58 PM
Revit Floor Finish Plan - Key
Thu, May 14, 2009 at 3:47:00 PM
Rendering in Revit Structure 2009?
Sat, Dec 24, 2016 at 5:11:53 AM
detail component
Tue, Jul 14, 2015 at 4:48:06 AM
Page generation time: 1.6129
