Forums >> Revit Building >> Technical Support >> Hosting a wall-mounted louver system to a mullion...
Tue, Jun 22, 2010 at 11:30:19 AM | Hosting a wall-mounted louver system to a mullion...
PatrickReynolds
PatrickReynolds Avatar
Is it possible to host a wall-mounted family to a mullion in a curtain wall?  I've created a louver system that needs to have its support brackets hosted against the mullions of a curtain wall.
Is there any way to do this?
Tue, Jun 22, 2010 at 11:49:41 AM | Hosting a wall-mounted louver system to a mullion...
Sorry but a mullion is not a wall. Is it possible to put a wall in that panel and host your louver?
Tue, Jun 22, 2010 at 12:02:34 PM | Hosting a wall-mounted louver system to a mullion...
PatrickReynolds
I actually had that brainstorm about five minutes ago, that worked.  I would prefer to have it be intelligently mounted, but so long as it's in the right place it should be fine.
Another question.  Would it be possible to change a wall mounted generic model so that it'll place against any face?
Tue, Jun 22, 2010 at 12:25:15 PM | Hosting a wall-mounted louver system to a mullion...
That question was also just asked.  You have to create a face based object.  Prior to 2011, you could not transfer anything between wall based and face based families.  However, in 2011, you can copy some elements.
Louver curtain wall system
Tue, Mar 11, 2008 at 3:05:47 PM
Louver family
Mon, Jul 7, 2014 at 11:56:40 AM
Changing family from wall mounted to ceiling mounted
Mon, Nov 16, 2009 at 2:19:09 PM
Handrail - Wall mounted
Fri, Apr 28, 2017 at 5:35:54 PM
wall mounted toilet wall error
Wed, May 6, 2009 at 3:41:37 PM
Page generation time: 1.0310
