Forums >> Revit Building >> Technical Support >> Converting .skp files to .rfa?
Tue, Jun 22, 2010 at 1:17:49 AM | Converting .skp files to .rfa?
ethand
Hi guys, I thought I was told ages ago that its possible to convert .skp files to .rfa for a quick and easy way of getting models into revit families for projects in revit architecture, etc.
Does anyone here know how this might work? If so, what programs can I use, etc.
Thanks!
Tue, Jun 22, 2010 at 2:30:59 AM | Converting .skp files to .rfa?
xzavoral
Press F1 in Revit and type "SKP" into search. You will find easy tutorial here.
It is done using "Import CAD" into family. Here you just select file type "SKP" at bottom.
Tue, Jun 22, 2010 at 4:06:36 AM | Converting .skp files to .rfa?
gebber
gebber Avatar
5 Stars: 4 Votes
And as you can see below there are many topics on revitcity about this.
Keep in mind when you import the rendering will be gray, use the revitcity search to find out how to aply the materials
Tue, Jun 22, 2010 at 4:20:10 AM | Converting .skp files to .rfa?
4 Stars: 205 Votes
There are hundreds of threads like this in Forum, search "Sketchup"....
Tue, Jun 22, 2010 at 7:53:34 PM | Converting .skp files to .rfa?
ethand
ok, thanks guys. I tried looking through the posts, but it took too long, and I didnt see any posts like this... i didnt think to search! Cheers guys
Wed, Jun 23, 2010 at 12:36:27 AM | Converting .skp files to .rfa?
gebber
gebber Avatar
5 Stars: 4 Votes
YoU DON'T HAVE TO SEARCH LOOK AT THE BOTTOM OF THIS PAGE
Wed, Jun 23, 2010 at 6:53:54 AM | Converting .skp files to .rfa?
ethand
yeh, but this thread didnt exist, remember? ahaha dw, all good got it sorted now Smile
Thanks again!
Wed, Jun 23, 2010 at 7:01:26 AM | Converting .skp files to .rfa?
gebber
gebber Avatar
5 Stars: 4 Votes
As I can see nice uploads
Fri, Jun 25, 2010 at 3:05:23 AM | Converting .skp files to .rfa?
ethand
ahahah thanks Smile more to come soon Smile
No colour for rendered skp files
Thu, May 7, 2009 at 10:24:37 AM
How to change material of an rfa files on the download sections?
Sun, Jul 12, 2009 at 9:27:06 PM
Uploading type catalog file directories with RFA files
Fri, May 14, 2004 at 12:49:21 AM
Using RevitCity 9.1 .rfa files using Revit 9.0
Fri, Jan 11, 2008 at 8:58:01 AM
Convert .skp to .rfa
Mon, Mar 5, 2012 at 2:09:18 PM
Page generation time: 0.4966
