Forums >> Revit Building >> Technical Support >> add edge to top of form
Sun, Jun 20, 2010 at 3:55:12 PM | add edge to top of form
stevek77
I've been at this for several hours now, so I thought I'd post this up... is there a way to add an edge to the top of a rectangular form? I am able to add profiles to said form (just a rectangular box), and edges to the sides, but Revit will not let me choose the top of the form to, for instance, create a gable roof form. Obviously, Revit can do this. How?
Mon, Jun 21, 2010 at 8:23:15 AM | add edge to top of form
Are you doing mass modeling, in-place family or actual family?  Are you in 2010-11 - ?
If you are in a project, just create a roof by footprint.
Tue, Jun 22, 2010 at 1:23:37 AM | add edge to top of form
stevek77
my roof is part of a complex mass for a grad school project. There is no way to add edges the top of a mass object, only the sides?
Tue, Jun 22, 2010 at 1:26:07 AM | add edge to top of form
stevek77
...wait a second, can what I want to do be done in project mode or do I have to use the conceptual massing environment to do this?
Tue, Jun 22, 2010 at 4:23:08 AM | add edge to top of form
4 Stars: 205 Votes
An image paint more than 1000 words so what are you trying to do? images please...
Thu, Jun 24, 2010 at 3:17:33 PM | add edge to top of form
stevek77
attached is a screenshot from revit of me trying to add an edge to the top of my mass in conceptual massing mode...I just get a circle with a slash through it.
Attached is a conceptual model I did in sketchup in 20 minutes - this is what I would like to do in revit, at least the roof shape roughly.
Fri, Jun 25, 2010 at 8:58:21 AM | add edge to top of form
4 Stars: 205 Votes
I can't see that in plan view BUT i believe you don't need the "conceptual mass" to create that kind of roof, just use "In-Place" family and use solid "Swept Blend" then you can define the Path and the two profiles (front and back).
Surface Toolbar in REvit
Mon, Nov 18, 2013 at 6:42:30 AM
Surface on solid form getting split after being edited by a void form
Wed, Aug 9, 2017 at 6:28:44 PM
why wont these join?
Sun, Nov 6, 2016 at 9:45:44 AM
how to add an edge in an conceptual massing
Sun, Jul 24, 2011 at 2:36:43 AM
adding radius edge to floor slab
Wed, Jul 21, 2010 at 7:47:29 AM
Page generation time: 0.4744
