Forums >> Revit Building >> Technical Support >> Family Visibility Controls
Fri, Jun 18, 2010 at 9:48:46 AM | Family Visibility Controls
Spacecowboy500
I've got a Nested Revit Family that I created using the Structural Framing Beams Template.  I created a void carton and nested it into the beam family.  I only want the void carton to show in medium or fine levels of detail as plan views are in coarse detail and I don't want the line work from the void cartons showing up in plan views.  I only want the void carton showing up in 3D or section views to speed up details and to facilitate interference checking in NavisWorks.
If I set the visibility options of the void carton to be hidden in coarse views in the family and load it into the project, it doesn't show up at all.  It's seems that Revit doens't allow you to control the visibility of single elements in a multi element family.
If anyone has any workarounds for this or has experienced the same problem, I would really appreciate some help.  Thanks
Fri, Jun 18, 2010 at 1:22:34 PM | Family Visibility Controls
Spacecowboy500
By the way, I am using Revit Structure 2010.  I just installed 2011 and the problem is the same.
Visibility controls
Mon, Apr 16, 2018 at 12:56:54 PM
building controls
Wed, Feb 3, 2010 at 8:26:27 AM
Void extrusion family visibility
Fri, Apr 22, 2022 at 7:57:52 AM
Flip Controls
Mon, Oct 20, 2008 at 10:43:50 AM
Flip Controls in Nested Families
Wed, Jan 16, 2008 at 1:47:48 PM
Page generation time: 2.8164
