Forums >> Revit Building >> Technical Support >> change one object’s color several others change
Tue, Oct 4, 2005 at 8:28:43 AM | change one object’s color several others change
vanorju
I have downloaded several objects from several different sources. Every time I change one object’s color several other object colors change at the same time. Is there a way to tell how they are all connected?
Tue, Oct 4, 2005 at 8:59:18 AM | RE: change one object’s color several others change
Rookwood
Typically you can select the 'OBJECT' you want to change and do so in the properties box. Select the object, go to the properties box, select Edit/New and 'DUPLICATE'. Change that objects properties and the others should remain as they were. If you don't duplicate the object, you change the properties for all instances of that object.
Wed, Oct 5, 2005 at 5:53:07 PM | RE: change one object’s color several others change
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I might add when solids are joined they tend to inheret the materials of the object they're joined to... In this case its often necessary to use the paint tool to paint the appropriate faces with the appropriate material.
i can not change the color of the line of my imported dwg object
Wed, Nov 11, 2015 at 9:01:57 AM
2011 change material color [ 1 2 ]
Sat, Aug 31, 2013 at 8:46:22 AM
16
How do you change the material and color of a download?
Tue, Aug 6, 2013 at 7:31:46 AM
Change floor color?
Wed, Jun 15, 2011 at 1:47:01 PM
Material Color Change not Rendering (...but Old one does)
Thu, Mar 6, 2008 at 8:38:56 AM
Page generation time: 0.6730
