Forums >> Community >> Newbies >> Tropical Trees
Thu, Jun 17, 2010 at 10:18:59 AM | Tropical Trees
droselle
I’m doing a project in Nigeria. I need to make the site model as realistic as possible. It would be incredibly helpful if someone could point me in the direction of where I could find trees that would fit in a tropical climate. Some of the RPC trees work but most are far too deciduous for the African rainforest.
Any help would be greatly appreciated.
Thu, Jun 17, 2010 at 10:44:43 AM | Tropical Trees
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
If you can't find a acceptable tree to download, download one that looks like a good start then modify the family to get the shapes you want. There might be something in the Google 3D warehouse that was originally done in SketchUp. These can be imported into Revit.
Thu, Jun 17, 2010 at 11:57:38 AM | Tropical Trees
droselle
Thanks. Can the model from sketch up be modified in Revit?
Thu, Jun 17, 2010 at 12:25:06 PM | Tropical Trees
4 Stars: 205 Votes
Only the material....
Fri, Jun 18, 2010 at 9:34:07 AM | Tropical Trees
Bimman
Bimman Avatar
1 Stars: 2 Votes
when you start up revit, under the main screen there is a web lib option under families.  once there, there is a link to a tress tab with 100 trees. maybe try there to see if there are any matches to your needs.
PWD
Wed, Jul 20, 2011 at 4:21:46 PM | Tropical Trees
iamian33
iamian33 Avatar
Greetings.
Ian Shafer
Principal Consultant
True North S&F Consultants
trees
Wed, Jul 3, 2013 at 1:55:49 PM
How to add bamboo into RPC trees in Revit?
Fri, Oct 8, 2010 at 1:44:57 PM
Foliage Generation...
Mon, Dec 1, 2008 at 9:47:48 AM
2D trees - Elevations
Wed, Oct 10, 2012 at 4:00:17 AM
Rendering Trees in Revit 2010
Wed, Apr 27, 2011 at 2:53:37 PM
Page generation time: 0.0352
