Forums >> Community >> Newbies >> Cant figure out why Family wont load into project
Thu, Jun 17, 2010 at 9:28:56 AM | Cant figure out why Family wont load into project
FWASDrafter
FWASDrafter Avatar
Can some plese help me figure out why this family wont load?
Thu, Jun 17, 2010 at 10:04:01 AM | Cant figure out why Family wont load into project
Dafpfy
3.5 Stars: 11 Votes
i think its because your familie does not change correctly to different wall withs,
change the wall with in you familie and see what goes wrong
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Thu, Jun 17, 2010 at 10:14:08 AM | Cant figure out why Family wont load into project
TomDorner
4.5 Stars: 25 Votes
Yes it will load into a project.  However you have created the family so it will only work with an exact 6" wall width.  When making families you violated one of the cardinal rules which is set up the logic via reference planes and parameters, flex,flex, flex to make sure it all moves logically, then add the geometry.
For hosted objects such as windows and doors, you also want to duplicate the standard wall 1 in the family editor and make a couple of thicker and thinner walls.  Swap out the host wall with the various wall thickness and see what happens.  In your case you will get a 'constraints not satisfied'.  I believe it is the sill giving the problem.
You also have an additional problem in that you failed to define a 'type' within the family.  Having at least one type defined is good [essential] Revit practice.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Thu, Jun 17, 2010 at 10:45:17 AM | Cant figure out why Family wont load into project
FWASDrafter
FWASDrafter Avatar
I found the Issue thank you Dafpfy. It has something to do with a constraint on the symbolic lines. I recreated the family from sctratch in 5 minutes and the new family works fine.
the family mass wont load into my project
Wed, Nov 10, 2010 at 1:46:28 PM
family wont load
Wed, Mar 21, 2012 at 10:39:48 AM
help! cannot load new column family into project
Wed, Jul 16, 2014 at 12:26:38 PM
Cant load families
Tue, Jan 5, 2010 at 12:05:32 PM
Family Won't Load
Tue, Nov 28, 2017 at 8:50:38 AM
Page generation time: 0.9348
