Forums >> Revit Structure >> Technical Support >> How do I place interior lights and flooring materials??
Thu, Jun 17, 2010 at 1:52:45 AM | How do I place interior lights and flooring materials??
ethand
Hi there, i'm new to revit architecture, and want to know how to place lights in the interior of building? I just cant figure it out, and can't seem to find any other posts/sites on the net that address this.
Also, I'd like to know how to change the floor materials, like if I want wooden or tiled flooring indoors?
Thanks in advance for your help!
Thu, Jun 17, 2010 at 2:21:42 AM | How do I place interior lights and flooring materials??
gebber
gebber Avatar
5 Stars: 4 Votes
a light can be placed as a component.
Be aware there are ceiling based and wall bassed lights wich can only be placed on a ceiling or a wall.
It might be a good idea to check the revit help to make you understand how revit works.
to change the flooring material
1 select the floor,
2 click edit type in your properties dialog
3 click edit structure here you can change the materials and the structure of your floor
Thu, Jun 17, 2010 at 2:29:43 AM | How do I place interior lights and flooring materials??
ethand
ok thanks a heap!
Can the ceiling mounted lights be mounted to the soffit (i.e the underside of the floor above it) or must I create a ceiling to place them? and which view do you have to be in to place a ceiling mounted light?
cheers
Render exterior view with artificial lights - how to make interior glow?
Sun, Mar 11, 2012 at 12:45:28 PM
how to apply flooring materials
Sat, Sep 2, 2006 at 2:49:34 PM
Exterior night rendering with interior lights on? R16
Wed, Aug 3, 2016 at 1:23:36 PM
rotating materials
Wed, Dec 26, 2007 at 10:45:40 AM
interior rendering, lights won't come on
Thu, Apr 25, 2013 at 10:42:56 AM
Page generation time: 1.9284
