Forums >> Revit Building >> Technical Support >> composite panel walls
Wed, Jun 16, 2010 at 4:59:57 PM | composite panel walls
RT21
what is the best way to build a composite aluminum panelled wall that will allow me to stretch or change panel sizes and show a reaveal at panel edges
Thu, Jun 17, 2010 at 1:17:34 PM | composite panel walls
4 Stars: 205 Votes
Like this? Curtain Walls....
Thu, Feb 24, 2011 at 12:18:48 AM | composite panel walls
jbrewlet
holy crap, how did you make the bevels on the panels? i really REALLY want to learn how to do that.
thread i started on just that issue... could you help?
http://www.revitcity.com/forums.php?action=viewthread&thread_id=23449
Thu, Feb 24, 2011 at 4:49:18 AM | composite panel walls
4 Stars: 205 Votes
Like I said: "Curtain Walls", just create a "Curtain wall panel" family like you want, in project divide the curtain wall like you need and replace the panels by the NEW panel you created.
Something like this: http://www.revitcity.com/gallery.php?action=view&gallery_id=7803
Thu, Feb 24, 2011 at 11:33:28 AM | composite panel walls
jbrewlet
Ah, well I got as much as this.
It gives me an error because they aren't perfect rectangles or something...sigh.
I edited the original Solid Panel that comes with revit to have a slight bevel.  It only bevels two sides because it's an extrusion and then of course the error with using them in my project.
Would someone mind helping me create a more flexible beveled that can adapt to differing size panels?
Thu, Feb 24, 2011 at 2:17:18 PM | composite panel walls
4 Stars: 205 Votes
"It gives me an error because they aren't perfect rectangles or something...sigh." - That's correct, in this case you will to create a "Metric/Imperial Curtain Panel Pattern Based" and create that in a different way, check this blog from ZACH KRON:
http://buildz.blogspot.com/
http://www.youtube.com/user/zachkron#p/u
Fri, Feb 25, 2011 at 1:32:37 PM | composite panel walls
4 Stars: 205 Votes
something like this:
Need Help Aligning /Locking Nested Components to Host Curtain Wall Panel
Fri, Sep 4, 2009 at 9:57:10 AM
changing line thickness in composite walls
Wed, Mar 25, 2009 at 7:11:09 AM
panel walls - getting walls to subdivide automatically with joints already in.
Wed, Nov 24, 2010 at 6:22:27 PM
Creating a composite Curtain wall
Mon, Mar 26, 2007 at 6:05:15 PM
composite column
Mon, Oct 16, 2006 at 1:53:30 AM
Page generation time: 0.9818
