25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> Rotate Project North results in 100's of errors.
We have a project that is 60% complete and now the consulting firm wants to change sheet sizes so we need to rotate project north 90 degrees counter clockwise for the project to fit on the sheets. When we do this we get 78 errors and 109 warnings and only the option to cancel the command with no way to resolve the errors. Any ideas?
turn on crop region, select crop region, rotate crop region voila
Rotate the drawing sheet.
I doubt you really mean "...We have a project that is 60% complete and now the consulting firm wants to change sheet sizes so we need to rotate project north 90 degrees counter clockwise for the project to fit on the sheets...." You don't rotate project north to fit your sheet. You only do that when you want to rotate a building on a site. And rotating project north should not have given you all those errors but if you tried to rotate the model, then you would have problems. What mbsteve told you is your best solution. It is called "rotate view by crop region". When you do this, all model elements rotate but all annotative elements remain readable with respect to your screen. And instead of rotating the sheet as bdbhoy suggests, you also have another tool called "rotating view on sheet". If you use this tool, the view and view title will rotate completely with respect to your sheet.
2 Posts No Rating |
I am having the same problem now, i tried it like mbsteve said, but it won't let me rotate the crop region if I select it...
you must be doing something wrong. select the crop region, it will highlight. then select the rotate object button, this will turn on a small circle with arrow and a line. you may move the small circle any where in your view with the cursor. then click the line and rotate. this works the same way as it does for all objects in revit.
2 Posts No Rating |
I tried it again today and now it did work... weird. Thanks for the help!
rotate PROJECT north (not true north) |
Wed, Jun 10, 2009 at 9:11:40 AM
Project North doesn't rotate back after changed to True North |
Fri, May 7, 2010 at 3:24:14 AM
Rotation Problem |
Fri, Mar 2, 2007 at 9:02:32 AM
Trying to rotate project north but imports wont turn |
Thu, Mar 13, 2014 at 12:43:52 PM
How to Rotate True North without rotating the whole Project? |
Thu, Mar 18, 2010 at 7:25:35 PM
