11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Turn off section references that occur in the background of an elevation
25 Posts No Rating |
I've got a number of elevations where the far clipping range goes WAY back to show the portions of the building that occur back there... We've all encountered this... The problem is: by setting the "Far Clip Offset" so far back - it picks up a whole bunch of wall & detail section references which are NOT relevant to my elevation. This means that I have to double check every single section reference that shows up in my elevations & manually hide the ones that are incorrect... Babysitting things in Revit is not fun... It always makes for errors & inconsistencies (kind of like AutoCAD). Is there a way to define how far back your elevation will display any adjacent section references? Or am I stuck doing this manually? If this doesn't make sense, I will show a few pictures.
I think you are stuck. ... and you do know about using your window and funnel filter to select multiple section references to hide in view?
Edited on: Wed, Jun 16, 2010 at 7:55:40 AM
i think you set to hide in views courser than a certain scale factor. just set that to a low scale and it would not show up. say set it to 1/8" and if section was at 1" then the marker would not show up becuae it is hidden.
----------------------------------- PWD |
Section References Disappearing |
Sun, Sep 13, 2009 at 11:40:02 AM
Topography and hatching in section / elevation |
Sat, Sep 27, 2008 at 7:55:41 PM
Revit 2011 Multiple Interior Elevation References |
Wed, Oct 26, 2011 at 9:01:48 AM
multiple section references |
Thu, Jan 8, 2009 at 2:56:42 PM
Section drawing references |
Fri, Jun 21, 2013 at 11:46:25 AM
