Forums >> Revit Building >> Technical Support >> Reflected Ceiling Plan Phasing problems
Tue, Jun 15, 2010 at 12:38:12 PM | Reflected Ceiling Plan Phasing problems
Rosader
I am working on an addition where I am showing both the existing ceiling grid and the new. I have the view properties set to "show complete" "new construction" and I am not able to select either ceiling by the edges or grid pattern. If I change the view properties to "show complete" "existing" I can select the existing ceiling just fine WHAT GIVES??? I need to be able to select the "new" grid pattern to move it to line up with the existing.
Tue, Jun 15, 2010 at 1:03:00 PM | Reflected Ceiling Plan Phasing problems
Rosader
OK it's not just ceilings I can not select anything but annotation in a ceiling view in this phase
Reflected ceiling plan
Fri, Mar 28, 2008 at 11:16:26 AM
Cannot open reflected ceiling plan
Fri, Jan 9, 2009 at 2:23:07 PM
Problem seeing doors in reflected ceiling plan
Mon, Jul 14, 2008 at 9:26:12 AM
REFLECTED CEILING PLAN
Thu, Jan 20, 2011 at 3:12:51 AM
Different Plan Title for Reflected Ceiling Plan
Mon, Aug 1, 2022 at 4:28:33 PM
Page generation time: 0.4894
