Forums >> Revit Structure >> Technical Support >> Family with dimension
Tue, Jun 15, 2010 at 3:26:49 AM | Family with dimension
satheeshbabu
Is it possible to create family with dimension? That is dimension should be visible out side in a family.
Please, someone help me.
Thu, Jul 1, 2010 at 5:22:20 AM | Family with dimension
4 Stars: 205 Votes
No, why do you want that? Just load the family into the project and then you can dimension what you want, remember, you must change the "Work Plane" every time you need to dim. horizontal / vertical planes
Thu, Jul 8, 2010 at 7:06:39 AM | Family with dimension
shaverjeff
Yes it is possible, at least for detail component families but I would also question the need.
Dummy dimension families can be created without too much effort as a linebased detail component, then nested into your other family.
You can utilize a nested label and set the value equal to the length of the line based family. Constrain this to always be centered
Then nest your desired ticks/arrows.  If you want to get really fancy you can utilize multiple reference lines and visibility parameters to control dimension extension lines.
Just note that dependant upon its use and whether you are constraining/locking this element in a nested family or in your project it is potentially dangerous to use as it will not have a relationship without manually constraining with the elements such as a native dimension. Admittantly I have used these in the past directly in details not nested) but that was prior to the dimension text overrides becoming available. (RS4 perhaps?)
Edited on: Thu, Jul 8, 2010 at 7:08:33 AM
Family Help Please! 'Labeling this dimension would overconstrain the sketch.'
Wed, Jun 10, 2015 at 9:18:40 AM
New Dimension Family
Mon, Apr 28, 2008 at 4:38:41 PM
Activate Dimension
Tue, Dec 13, 2011 at 12:53:44 PM
Dimension strings not adding up to the total length dimension string (2017)
Fri, Mar 23, 2018 at 1:33:58 AM
Change length of dimension, and parts of family
Thu, Nov 16, 2017 at 8:27:51 AM
Page generation time: 2.7133
