Forums >> Revit Building >> Technical Support >> Array Formulas
Mon, Jun 14, 2010 at 11:41:21 PM | Array Formulas
mgruenba
Hi,
I need to design a new family for a patio cover system comprised of several beams. There is a standard separation of 4-1/2" between the beams. I would like to be able to enter the width of the patio cover and have Revit add or subtract the needed (or unneeded) beams. Does anyone know how I would do this? Would I use array formulas for this? I'm clueless right now. Help please.
Thanks
Tue, Jun 15, 2010 at 2:10:34 AM | Array Formulas
Dafpfy
3.5 Stars: 11 Votes
use reference planes for the two outer beams and a formula on the array.
Set the parameter with the formula to integer and i think revit will add or remove beams like you whant.
i have made similar families so it is possible,,,
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Wed, Jun 16, 2010 at 9:37:47 AM | Array Formulas
mgruenba
Thank you so much for your help. I've never used array formulas before. Could you provide some more information on the format for a formula? Where do i enter the formula?
Thu, Jun 17, 2010 at 4:55:45 AM | Array Formulas
Dafpfy
3.5 Stars: 11 Votes
in the family editor, in the types window, next to where you would usualy fill in your parameter, there is a column called,
Formula,
using the F1 help menu will also help you a lot of the way.
note that you can also use names of other parameters in these formulas,
example,   =(Height +500mm ) / 2
GL
Edited on: Thu, Jun 17, 2010 at 4:57:43 AM
peace is the path."
Mahatma Gandhi.
Sun, Jun 20, 2010 at 6:52:38 PM | Array Formulas
mgruenba
Thank you once again for all your help. One last question.
So I've made the formula and the formula works. Now, how do I connect that formula to the beams? In other words, with that formula in place, how do i assign that formula to the beams that I want in place?
I would greatly appreciate your help.
Regards
Mon, Jun 21, 2010 at 12:25:16 AM | Array Formulas
mcantwell
mcantwell Avatar
Would a beam system do what you want?Edited on: Tue, Jun 22, 2010 at 5:50:29 PM
Edited on: Fri, Jun 25, 2010 at 6:31:27 AM
Mon, Jun 21, 2010 at 8:44:31 AM | Array Formulas
TKennedy
4 Stars: 8 Votes
Select one of the arrayed objects. You should get a line with a number similar to a temporary dimension. Select the line and one the options bar there will be a dropdown where you can assign your parameter.
Thu, Jun 24, 2010 at 9:58:40 AM | Array Formulas
mercat11
I seem to be having an issue with a version of this... I have a working formula for arraying timber beams in a brise soleil setup (Calculated Internal Width / Fin Spacing) which works fine front to back but when increasing the width the array slants from one (interpolates between its current location at one end and the new location at the other (pics attached)) Ive been trying to set it up with instance paramter dimensions to allow quick control on plan and with using both in plcae geometry and nested family geometry.. Revit 2009 SP3
Thu, Jun 24, 2010 at 10:09:49 AM | Array Formulas
Dafpfy
3.5 Stars: 11 Votes
Align and lock the first and the last to a ref plane.
peace is the path."
Mahatma Gandhi.
Thu, Jun 24, 2010 at 10:12:51 AM | Array Formulas
Dafpfy
3.5 Stars: 11 Votes
or allign and lock to your frame in this case
peace is the path."
Mahatma Gandhi.
Fri, Jun 25, 2010 at 4:31:21 AM | Array Formulas
mercat11
Thanks for reply - I had tried aligning and locking to both the frame and ref plane but it seems that if beam is group arrayed (for formula) then this overrides the align and lock. Having a new parameter to control the nested instance dimension parameter (for the nested beam family) means an align and lock isnt necessary. It seems to work and flex ok with this method.
Cheers again.
Understanding Formulas
Tue, Nov 16, 2010 at 1:36:05 PM
14
Formulas, arrays and track lighting
Thu, May 14, 2015 at 8:31:48 PM
Array Formula Problems
Tue, Jul 26, 2011 at 2:30:54 AM
Variable Length Family with Array Formula
Wed, Aug 8, 2012 at 9:56:46 AM
to import shared parameters with formulas.
Fri, Jun 20, 2014 at 7:19:05 AM
Page generation time: 1.9705
