19 Users Online (17 Members):
Forums >> General Discussion >> Wishlist >> KALWALL?
IM WORKING ON A PROJECT I HAVE TO DO A RENDERING FOR AND I NEED TO FIND A TEXTURE FOR REVIT THAT IS SIMILAR TO KALWALL. DOES ANYONE KNOW OF ANYPLACE I MIGHT BE ABLE TO FIND SOMETHING I CAN USE?
16 Posts No Rating |
Try making your own wall type & adjusting the transparency of the material
eg you can make one up from glass then adjust it to suit You will have to play /render a couple of times
to get the effect you want but it should work for you
Hope this helps
The project I am working on has a self supporting Kalwall section on the main roof. I modeled it as a curtain wall system but am having trouble with the ridge (corner) joints. Was wondering if any body has ever done this and if so how you modeled it. Thanks.
