Forums >> Revit Building >> Technical Support >> Revit glass looks flat
Mon, Jun 14, 2010 at 4:18:56 PM | Revit glass looks flat
archie456
3 Stars: 1 Votes
Hi,
I'm starting to render my building - but the glass in the windows looks a little flat and unconvincing.
I think the problem is that my building is not surrounded by anythign and so the glass is not reflecting anything.
In Max I would put a reflection map on the glass material which would fix the problem. The map would show other buildings from the site and a bit of sky.
Can this be done in Revit??
Cheers.
Mon, Jun 14, 2010 at 5:40:09 PM | Revit glass looks flat
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
go to the gallery above. you will see a bedroom interior view, note that there is a lawn and shrubry out side. I am not sure if it was modeled on the outside, or touched up in Gimp, or photo shop. you can also add decals, which might get tricky to get the correct transparency.
curved curtain system -diagonal grid system?
Wed, Feb 11, 2009 at 4:24:47 PM
Glass behaving oddly
Thu, Nov 27, 2014 at 11:05:47 PM
Glass Opacity
Sun, Aug 11, 2013 at 3:10:08 PM
Transparency of glass windows in 3d views
Wed, Aug 5, 2009 at 10:43:37 AM
Revit to 3Dsmax vray glass problem
Tue, Jan 21, 2014 at 8:47:01 AM
Page generation time: 2.6600
