Forums >> Revit Building >> Technical Support >> How do i create Formwork for walls and slab using revit architecture.?
Mon, Jun 14, 2010 at 4:47:55 AM | How do i create Formwork for walls and slab using revit architecture.?
santungs
anyone? im stuck on this...basically i need the standard offset for the each 1200mm x X 900mm, let say i had a wall that lenght 6m..so how do i create this wall divide each into each panel, then the balance remain in what so ever, in addition i need it to automatically key in also the text of the sizes..? (im trying to use the curtain wall sytem, but i dunno if its appropriate).
the same problem with the slab also, but slab i had not figure it out how do i do this...Anyone can helo?
many thanks in advance.
Mon, Jun 14, 2010 at 5:07:58 AM | How do i create Formwork for walls and slab using revit architecture.?
4 Stars: 205 Votes
I think i create that by "Curtain Walls"...
Mon, Jun 14, 2010 at 11:58:17 AM | How do i create Formwork for walls and slab using revit architecture.?
Bimman
Bimman Avatar
1 Stars: 2 Votes
i downloaded a revit extension pack for 2010 architecture, that had a framing creator in it.  you layout the wall and you can specify headers, jacks, and king stud as weel as framing spacing. works petty nice.
PWD
Showing walls from the bottom of slab
Tue, Feb 9, 2010 at 10:40:40 AM
How to compute formwork
Sat, Mar 17, 2012 at 3:00:07 PM
Revit Architecture / Revit Structure Coordination Issues
Fri, May 7, 2010 at 10:19:04 AM
How do I get a slab system family into my project?
Tue, Mar 17, 2009 at 12:52:42 PM
Create Void as Slab Edge
Sun, Oct 2, 2016 at 11:39:37 PM
Page generation time: 3.4025
