10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Using the split element tool
Hi, I've created a wall which I want to cut horizontally, so I can change the top portion to a different type. Annoyingly, when I use the split element tool in a 3D view, it wants to cut the wall vertically, I cannot get it to change to horizontally. Is there any way of toggling between horizontal and vertical? What am I doing wrong. Cheers.
OK, I found the problem - I'm using a stacked wall which, apparently, you cannot split horizontally. I used the break apart command which fixed my problem. Is there any advantage of keeping the wall as a stacked wall?
Stacked walls are very good for initial placement but because they can give you fits in some cleaup conditions, I usually break them up after they are placed. Remember, stacked walls are just that, idividual walls that are stacked. The composite is not a true wall type and each wall in the stack schedules and tags seperately.
using split face tool on curved walls |
Sat, Oct 12, 2019 at 8:21:20 AM
Topography split tool issue |
Thu, Apr 18, 2019 at 5:55:11 AM
split precast wall |
Fri, Nov 24, 2017 at 1:17:55 AM
split face tool on curved extrusion |
Thu, Nov 20, 2008 at 3:33:50 PM
13
Split Face Tool |
Wed, Dec 14, 2016 at 1:39:53 PM
