Forums >> Revit Building >> Technical Support >> Missing Studs in all drawings
Fri, Jun 11, 2010 at 2:55:38 PM | Missing Studs in all drawings
612steve
Hellow all and thanks in advance for your help.
Just about to print a bid set and all of our 3 5/8" studs dissapeared out of all  drawings. It still shows up in the component menu, but I cannot insert it. tried remaking it, but there is still nothing to insert. Any advice on what to troubleshoot next?
Using Revit 2010.
Will not Dimension to Studs
Fri, Jul 18, 2008 at 9:00:38 AM
Dimensions missing from the exported cad drawings
Fri, Jun 6, 2008 at 2:47:30 AM
Using Revit MEP to make ductwork shop drawings
Wed, Jun 15, 2011 at 9:52:02 PM
Wood studs
Mon, Mar 31, 2008 at 2:24:59 PM
wall pattern with studs and insulation
Sun, Oct 28, 2007 at 12:37:22 PM
Page generation time: 2.2419
