Forums >> Revit Building >> Technical Support >> Importing (civil) CAD in Revit
Fri, Jun 11, 2010 at 12:55:58 PM | Importing (civil) CAD in Revit
jgmas
I have an autocad file 2D, when I import it in Revit (as link or import) something happens, lines are not where they should be or the length or some of the lines change from the cad file to when I import/ link it in revit (a line in CAD 820ft is 1'-6" shorter in Revit). In CAD: two lines on top of each other (edge of walk and property line) in Revit they are almost 11" apart when I import / link the file. I already tried several things, like center to center, origin to origin, moving the cad to 0,0 point, shared coordinaes, purging the files, removing extra layer in CAD, etc. also tried import/linking in revit 2009 2010 and 2011, none of those worked. any ideas,
Mon, Jul 9, 2012 at 6:54:21 PM | Importing (civil) CAD in Revit
samuelfour
The issue with importing Civil CAD Drawings into Revit is the presence of lines which are "slightly off axis."  Revit does not like this, and attempts (without asking) to straighten all slightly angled linework.  There appears to be no way to stop this action.  Revit will redraw the lines straight, and possibly drag any other connecting lines with it.
The only solution is to delete any lines which are slightly off axis from the CAD background.  After importing to Revit, retrace the missing lines with Detail Lines.
This is a bug and another example of AutoDesk not designing a proper interface between Revit and AutoCAD.
Mon, Jul 9, 2012 at 7:12:30 PM | Importing (civil) CAD in Revit
samuelfour,
I think you are incorrect.  Whenever I import CAD files that are slightly off axis, they import correctly - I just get the "off axis" warning.
I'm not sure what the original poster's problem was.  I have seen some CAD files look incorrect on the screen but still printed OK.
matching contour lines from civil CAD when creating Topography (2019)
Fri, Dec 4, 2020 at 2:09:46 PM
Linking a civil 3D CAD file to Revit Architecture 2012
Thu, Jan 12, 2012 at 6:48:02 PM
Importing LandXML to Revit
Sat, Dec 11, 2010 at 2:59:51 PM
Civil Construction Drawings in Revit Architecture 2013
Sun, Jan 31, 2016 at 2:37:03 AM
Civil 3d surface to revit topo surface
Thu, Oct 13, 2011 at 7:14:34 AM
Page generation time: 2.1872
