12 Users Online (10 Members):
Forums >> Revit Building >> Tips & Tricks >> Revit 2011 products crash when attempting to replace material render appearance
Published date: 2010-Jun-09 ID: TS15255349 Applies to: Autodesk® Revit® Architecture 2011 Autodesk® Revit® MEP 2011Autodesk® Revit® Structure 2011 Issue When you attempt to replace a Revit 2011 material render appearance the application crashes with an Autodesk Revit has stopped working error. Solution The crash is related to the render appearance library previews. The following process should prevent the crash from occuring: - Manage > Materials.
- Render Appearance tab.
- Next to preview image, click on the down arrow icon to display shape options and render quality options.
- Set quality > Rendered – Draft Quality.
- Click OK to close Materials dialog.
- Manage > Materials > Render Appearance tab > Replace…
Revit should not crash after the quality is set > Rendered – Draft Quality. After changing the quality to draft and verifying the render appearance library does not crash, the preview quality can typically be set back to medium or high quality without subsequent crashes.
Edited on: Fri, Jun 11, 2010 at 12:34:38 PM
50 Posts No Rating |
I have tried this solution twice and Revit stops when I hit OK, after following all the steps. I am dong this in a brand new family (2011). any more ideas?? Thanks
I had same problem and could not modify materials, it crashed every time I hit ok. This helped:http://revitclinic.typepad.com/my_weblog/rendering/ in my case I had to uninstall the Wacom tablet drivers (solution1)
2 Posts No Rating |
My problem was solved with a simple issue:
When you're in the 'Render Appearance Tab, make sure you also check the 'Relief Pattern' Box. This will definitely solve the issue. So I say....follow Typhoons same instructions but after setting the quality to 'Draft', make sure to check the 'Relief Pattern Box'.
1 Posts No Rating |
for your information, it seems this concern is linked to a trouble with wacom pen tablet drivers
you may also disable the driver while using revit, which sometimes solves the problem
2 Posts No Rating |
Wow really? That makes so much sense, because I have an Intuos 4 tablet. No wonder. Thanks for the info....helps alot
1 Posts No Rating |
The Autodersk site has the fix:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15255349&linkID=9243099
Good Luck
Revit 2011 Custom Material Crash (Video) |
Tue, Jun 7, 2011 at 1:23:21 PM
Adding new render material |
Wed, Nov 2, 2011 at 10:39:45 PM
Revit Crashes. Help please. |
Wed, Oct 6, 2010 at 11:02:04 AM
Render Appearance Library - Reloading |
Wed, Mar 18, 2009 at 1:04:31 PM
Material Appearance in Revit 2019 |
Tue, Apr 28, 2020 at 10:44:51 AM
