Forums >> Revit Building >> Technical Support >> access to help file in Revit Architecture 2011
Tue, Jun 8, 2010 at 10:09:48 PM | access to help file in Revit Architecture 2011
jberri
I have recently loaded Revit Architecture 2011.
Wen pressing F1 to access user's guide I am directed to the online guide instead
of the help files which presumably should be loaded with the software within the computer.
Is anyone experiencing this problem ? How to correct it?
Wed, Jun 9, 2010 at 7:36:00 AM | access to help file in Revit Architecture 2011
It looks like we only have on-line HELP now.  I don't like it.
Wed, Jun 9, 2010 at 11:44:12 AM | access to help file in Revit Architecture 2011
coreed
coreed Avatar
4 Stars: 16 Votes
welcome to the future of Help gentlemen. i don't like it either. but some people didn't like the automobile also. guest  i will get use to it.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Jun 9, 2010 at 12:25:48 PM | access to help file in Revit Architecture 2011
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Switch between local and online help documentation for Revit 2011 products
Published date: 2010-Apr-14 ID: TS14994272
Applies to:Autodesk® Revit® Architecture 2011Autodesk® Revit® MEP 2011Autodesk® Revit® Structure 2011
Issue
You would like to know if you can set the default location for Revit® 2011 help documentation.
Solution
There are two options for specifying where Revit 2011 products will look for help documentation.  You can customize the location by adding the following information to the Revit.ini file.
The Revit.ini file is located in the following folder:
  • Autodesk Revit Architecture 2011C:\Program Files\Autodesk\Revit Architecture 2011\Program
  • Autodesk Revit Structure 2011C:\Program Files\Autodesk\Revit Structure 2011\Program
  • Autodesk Revit MEP 2011C:\Program Files\Autodesk\Revit MEP 2011\Program
Add the following 3 lines to the bottom of the Revit.ini file:
[Documentation]
UseHelpServer=1
HelpBrowser=0
  • To specify online help documentation use UseHelpServer=1
  • To specify local help documentation use UseHelpServer=0
Additionally you can further customize which web browser help documentation will launch with:
  • To specify the system default browser use HelpBrowser=0
  • To specify Microsoft Internet Explorer® use HelpBrowser=1
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14994272&linkID=9243099
Edited on: Wed, Jun 9, 2010 at 12:44:02 PM
Wed, Jun 9, 2010 at 12:39:01 PM | access to help file in Revit Architecture 2011
coreed
coreed Avatar
4 Stars: 16 Votes
thanks erland73
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Jun 10, 2010 at 12:35:49 AM | access to help file in Revit Architecture 2011
jberri
I have amended the Revit.ini file as recommended but without any effect.
 I am still directed to the Online help files.
Any hints?
Thu, Jun 10, 2010 at 12:47:58 PM | access to help file in Revit Architecture 2011
If you have done this correctly, this does work.  If it looks the same, that is because the locally installed HELP is in HTML fomat.  When you open the help, look at the address and you will see that it is the path on your machine.
Thu, Jun 10, 2010 at 10:51:02 PM | access to help file in Revit Architecture 2011
jberri
Yes it does work.
I was confused because the page looked the same as online.
Many thanks for your help.
Using 3D Studio Objects in Revit Architecture 2011
Tue, Sep 20, 2011 at 12:09:53 AM
Quick Access Toolbar 2011 losing tools on startup
Thu, Aug 19, 2010 at 6:43:53 AM
Re-installing Revit Architecture 2011
Tue, Dec 13, 2011 at 1:26:18 PM
I Can't use RPC content in Revit Architecture 2011
Fri, Jun 4, 2010 at 9:46:20 AM
Autocad Architecture join the Revit Architecture Suite
Tue, Aug 19, 2008 at 9:14:55 AM
Page generation time: 2.3501
