12 Users Online (10 Members):
Forums >> Community >> Newbies >> autocad site used in Revit
1 Posts No Rating |
Hi, does anyone know which changes i need to do in an Autocad topography file so i can use it in a Revit file?
Use the Contours lines with the right elevation (Z) then import that CAD file into a Site view plan then in Site TAB click on Toposurface > Use imported > import instance, click on the DWG file then select the layers you want (in this case only the Contours lines, minor and major), click OK then finish the surface, check your HELP menu for that if you have more doubts...
Using a 2D AutoCAD site drawing under a (nominally) Revit model |
Tue, Aug 14, 2012 at 12:33:08 PM
Linking AutoCAD Site Contour missing 2014 |
Wed, May 27, 2015 at 7:56:32 AM
Importing AutoCAD to REVIT |
Thu, Oct 22, 2009 at 2:56:44 PM
Site-contour |
Wed, Aug 23, 2006 at 5:57:17 AM
To convert autocad x,y,z points into a site din revit project |
Tue, Nov 29, 2005 at 3:05:11 AM
