Forums >> Community >> Newbies >> To Upgrade or Not to Upgrade? That is the question.
Mon, Jun 7, 2010 at 12:37:31 PM | To Upgrade or Not to Upgrade? That is the question.
dbillings3
Has anyone transitioned to 2011 Architect in the middle of a project? I'd like to use the new version, but I'm afraid of what my "saved in the new version" files might do to the rest of the project team. Any experience out there?
Mon, Jun 7, 2010 at 12:55:30 PM | To Upgrade or Not to Upgrade? That is the question.
Upgrading depends on may factors.
  1. First and most important - Your team including consultants.  Are they ready to upgrade?  Will their equipment work with the upgrade?  Don't guess at this - verify it.  You can always do a tested upgrade.
  2. Project Size.  Very large projects might overtax your system in an upgrade. ... again - you can test.
  3. Number of linked REVIT files.  I advise you to turn off any links in the main file prior to upgrading and to upgrade each of those linked files seperately.
  4. Where are you in the project?  If you are close to finishing ... why chance it?  What advatages will it give you?
UPGRADE QUESTION
Mon, Jun 12, 2006 at 9:03:39 AM
UPGRADE problem!!!
Wed, Jun 28, 2006 at 6:35:24 AM
Revit Upgrade from 2009 to 2012
Wed, Oct 19, 2011 at 7:08:21 AM
upgrade
Fri, Oct 13, 2006 at 2:22:22 PM
why not upgrade??
Fri, Sep 16, 2005 at 10:52:16 AM
Page generation time: 4.2331
