14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Line Weight
11 Posts No Rating |
Hi All, I'm hoping I can find some help. I'm working on a site plan in Revit '08. I need the outline of the site and the walls of the structure to have a heavier lineweight than the rest of the drawing. Is there a way to control the lineweight for these specific entities? I would greatly appreciate any help.
4 Posts No Rating |
Not sure if i get the problem but to change a line independent of any outer go in to linework and you there have a tool to change the specific line, the short key to this tool is ''LW'' hop it works Martin
you can also select the line and then right click and select graphic overrides and adjust it there. or in your view visibility by changing the settings there for the view. you can look in your help menu under grahic overrides for additional solutions.
----------------------------------- PWD |
Line weight in family doesn't equal line weight in project |
Fri, May 31, 2013 at 2:54:29 PM
Line Weight as Family Parameter |
Fri, Mar 16, 2007 at 4:23:58 PM
Making Line Weight a Parameter? |
Mon, Mar 19, 2007 at 1:59:55 PM
Column Grid Line Weight |
Sun, Aug 13, 2017 at 3:05:53 AM
Impossible to change ceiling pattern line weight |
Tue, Jan 22, 2013 at 11:03:23 AM
