Forums >> Revit Building >> Technical Support >> In Revit, the Navisworks File Exporter is grayed out on the ribbon menu
Fri, Jun 4, 2010 at 12:42:22 PM | In Revit, the Navisworks File Exporter is grayed out on the ribbon menu
4 Stars: 205 Votes
Published date: 2010-May-20
Applies to:Autodesk® Navisworks® Manage 2011
Autodesk® Navisworks® Manage 2010
Autodesk® NavisWorks® Manage 2009
Autodesk® Navisworks® Review 2010
Autodesk® NavisWorks® Review 2009
Autodesk® Navisworks® Simulate 2011
Autodesk® Navisworks® Simulate 2010
Autodesk® NavisWorks® Simulate 2009
Autodesk® Revit® Architecture 2011
Autodesk® Revit® Architecture 2010
Autodesk® Revit® MEP 2011
Autodesk® Revit® MEP 2010
Issue
When you attempt to access the Navisworks exporter from the Revit > Add-ins > External Tools menu option, the Navisworks 2011/2010 option is grayed out and unusable.
Solution
In order for the exporters to be selectable and usable in Revit, you need to ensure the following:
1.) You are in a 3d view of your model
2.) You do not have a building tool selected (press escape to exit out of any active tool)
Now, when you click Revit > Add-ins > External Tools, the Navisworks 2010/2011 option should be available for use.
Here, the Original post from Autodesk: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15175410&linkID=9243099&CMP=OTC-RSSSUP01
Edited on: Fri, Jun 4, 2010 at 12:43:16 PM
NavisWorks Exporter
Mon, Mar 28, 2011 at 3:40:00 PM
2016 export Revit files to Navisworks without using Navisworks Exporter.
Thu, Apr 21, 2016 at 4:53:15 PM
When you attempt to use the Navisworks exporter in Revit, a “localization” error
Fri, May 18, 2012 at 6:53:59 AM
Revit to Navisworks - No exporter in 2010
Thu, Aug 6, 2009 at 9:04:11 PM
Exporting to Navisworks 2009
Thu, Mar 5, 2009 at 6:41:39 PM
Page generation time: 3.0852
