Forums >> Revit Building >> Technical Support >> Curved roofs with bullnose eaves
Fri, Jun 4, 2010 at 6:44:40 AM | Curved roofs with bullnose eaves
archie456
3 Stars: 1 Votes
Hi,
I'm trying to create a curved roof with bullnose eaves.
Attached is a pic from AutoCAD showing what I would like to acheive.
Essentially, the roof has two curves as seen from the end elevation and is extruded down the length of the building.
I would appriciate some advice on the best way of creating this.
Cheers.
Fri, Jun 4, 2010 at 7:17:16 AM | Curved roofs with bullnose eaves
You can create this roof by extrusion in the horizontal direction.  Use the profile that you show in elevation.
Fri, Jun 4, 2010 at 10:14:13 AM | Curved roofs with bullnose eaves
archie456
3 Stars: 1 Votes
I tried roof by extrusion.
Whilst it creates the roof OK, it only has square or plumb edges, and not bullnose (i.e. round).
Am I missing something?
Fri, Jun 4, 2010 at 10:36:14 AM | Curved roofs with bullnose eaves
4 Stars: 205 Votes
Use the create "In-Place" in "Roof" category and choose "Solid Extrusion" then draw the shape like you want...
Edited on: Fri, Jun 4, 2010 at 12:48:15 PM
Fri, Jun 4, 2010 at 3:30:52 PM | Curved roofs with bullnose eaves
archie456
3 Stars: 1 Votes
Perfect - Thanks.
Fri, Jun 4, 2010 at 4:17:36 PM | Curved roofs with bullnose eaves
archie456
3 Stars: 1 Votes
Sorry - Another question about this!!
Whats the best way of cutting the walls to the underside of the roof?
The cross walls, I did edit profile and picked the underside of the roof which worked a tread, but I can't do this with the walls along the length of the roof due to the curve.
Is there a better way?
Thanks.
Fri, Jun 4, 2010 at 4:18:35 PM | Curved roofs with bullnose eaves
archie456
3 Stars: 1 Votes
D-oh!
So OK, you can attached a wall to a roof - that was easy!
Sat, Jun 5, 2010 at 11:30:22 AM | Curved roofs with bullnose eaves
4 Stars: 205 Votes
Smile
Bullnose roofs
Wed, Apr 27, 2005 at 10:04:39 AM
Curved Roofs.... a different sort of curve
Sun, May 10, 2009 at 9:46:59 PM
Bullnose verandahs
Wed, Jun 10, 2009 at 11:42:37 PM
Running Bullnose !
Thu, Sep 3, 2009 at 12:43:10 AM
Hip Roof with curved flared ends eaves
Fri, Apr 24, 2020 at 5:53:04 AM
Page generation time: 2.5012
