13 Users Online (11 Members):
Forums >> General Discussion >> Revit Project Management >> showing metric and imperial elevations
hi is there a way to show imperial and metric on elevations. we are doing metric and imperial on every dimension and notes and the project requires that also the elevation markers show metric and imperial measurements. any advice will be much appreciated.
You should be able to modify the tag so that it has two marks - one in each unit.
i open the level family, try to modify it but no luck i also loaded a generic annotation and placed some yes/no parameters and it work in the family editor but when i loaded into the model i dont see any of those parameter. Place some text so i can manually change it but everytime i loaded i can change it. the only way to do it is to add text below the metric elevation. But we have lots of elevations, sections, and details. see below. NAME METRIC ELEVATION [IMPERIAL ELEVATION]
Ah.... now you say level marker - that's different than " elevation". Check out this thread: http://www.revitcity.com/forums.php?action=viewthread&thread_id=13255
WWHub, THANK YOU SO MUCH.
Change from Metric to Imperial |
Sun, Feb 17, 2013 at 9:26:03 AM
Imperial metric question RAC2009 |
Fri, Jan 9, 2009 at 11:35:51 AM
Imperial to Metric |
Fri, Aug 8, 2008 at 4:11:17 PM
Imperial and Metric sheets and views |
Thu, Dec 16, 2010 at 3:32:05 PM
Change imperial to metric |
Wed, Mar 11, 2009 at 9:20:24 AM
