Forums >> Revit Building >> Technical Support >> Wall - vertical structure - delete layer
Thu, Jun 3, 2010 at 10:35:38 AM | Wall - vertical structure - delete layer
archie456
3 Stars: 1 Votes
Hi,
is it possible to create a wall of, say, brickwork, and then have render over the brickwork starting from about 2000mmm from datum - so the top part would be render, whereas the bottom part would be brick - but the render would sit on top of the brick.
 I've tried to do this by using Modify Vertical Structure in the Edit Assembly dialog.
I created a render layer of 25mm then 100mm brick as layer 2.
I clicked 'Split Region' and cut the render layer at 2000mm from datum.
What I want to do is delete the lower area of render (below 2000mm).
 Is this possible, I cannot see how you can delete parts - the delete button is unavailable.
 Thanks for any advice.
Thu, Jun 3, 2010 at 10:44:00 AM | Wall - vertical structure - delete layer
4 Stars: 205 Votes
Why don't you use "Stacked Walls"?
Thu, Jun 3, 2010 at 5:10:52 PM | Wall - vertical structure - delete layer
archie456
3 Stars: 1 Votes
Yes - Perfect - Thanks.
Structure layer of furring wall cleaning up with structure of concrete wall.
Mon, Nov 3, 2008 at 9:48:00 AM
Wall with horizontal and vertical battens
Thu, Apr 22, 2010 at 4:01:20 PM
Modifying a wall structure
Tue, Mar 3, 2009 at 3:55:51 AM
Revit Arch 2015 - Wall - Hide a Wall Layer line
Tue, Oct 28, 2014 at 12:30:39 AM
door sash/head to project from a particular layer of a wall
Fri, Apr 24, 2015 at 1:46:50 PM
Page generation time: 2.2460
