Forums >> Revit Structure >> Technical Support >> Revit 2011 upgrade
Wed, Jun 2, 2010 at 8:09:41 AM | Revit 2011 upgrade
Scottbim
I am about to upgrade to 2011 from 2010 is there any serious issues with doing this at the moment.
Also have revit sorted out there ASB section family to export/import to Fastrak yet
Thanks
Thu, Jul 1, 2010 at 5:33:34 AM | Revit 2011 upgrade
4 Stars: 205 Votes
There was some stability problems but they were corrected with the "Update 1", check here: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=14973244
Thu, Jul 1, 2010 at 8:48:12 AM | Revit 2011 upgrade
Bimman
Bimman Avatar
1 Stars: 2 Votes
i still seem to crash about 2-4 times a day, even after the update which did help it was much higher.  but i think it is related to my video driver we have fx 570's in all of our machines. when i open up 11' i get a warning about my video driver.  we are working on trying to update the driver or upgrade the card.  not sure what the best thing to is, or what card works best with revit.
PWD
Thu, Jul 1, 2010 at 9:14:01 AM | Revit 2011 upgrade
4 Stars: 205 Votes
Bimman, watch this: http://www.revitcity.com/forums.php?action=viewthread&thread_id=20595
Your graphic card in on the list
Thu, Jul 1, 2010 at 9:38:34 AM | Revit 2011 upgrade
Bimman
Bimman Avatar
1 Stars: 2 Votes
by switching to 2gb from 3gb, will this change anything else on my computer. i just did it and everything seems to be loading alot slower.
PWD
Thu, Jul 1, 2010 at 10:01:23 AM | Revit 2011 upgrade
xzavoral
It slowers everything that requires some memory to temporary store files. Like loading as you expirienced.
If all computer takes 1 GB (Win Vista) you end with only 1 instead of 2 so it will be 2 times slower (not exactly but you see the point).
The priority of todays computers is 64bit version of Operation system for workstations.
We use 64bit Windows Vista with 8 GB of RAM (or 4 on some computers).
Thu, Jul 1, 2010 at 10:11:57 AM | Revit 2011 upgrade
Bimman
Bimman Avatar
1 Stars: 2 Votes
so this seems to be more of an issue with 32 bit systems, that only have a max of 4Gb. but mine is act 3.25 after windows takes what it needs.  So in theroy if Revit grabs 3 and it then only leaves 1 for everything else. thus creating a big drain and crashing.  Am i seeing that right.
PWD
Fri, Jul 2, 2010 at 2:15:27 AM | Revit 2011 upgrade
xzavoral
Slightly different:
32 bit Operation system has 32 bit Kernel that has 34,359,738,368 adressses
4GiB = 4x (8x1024x1024x1024)
So the limitation would be 4 GiB of memory BUT (big BUT)
the computer has more Hardware than just RAM so the more hardware you have to adress, the less memory you see in 32bit Operation system.
Someone see 3,5 GiB of RAM (and has 4 GiB inside PC) and someone 3,0 (and has 4 GiB inside PC).
You see the result ?
The problem is probably that Revit want to "use" all memory, but the 32bit system can't adress whole 4 GiB -> Crash.
Also note that graphic cards for CAD uses huge amount of adresses itself so that maybe the case here ...
You have 3 GB but the graphic uses adressses of amount 1 Gig and rest of HW 0,5 Gig so you are:
4 (max) - 1 (graphic) - 0,5 (other HW) = 2,5 GiB than Revit wants "all" the 3 GiB ->Crash
When you have only 2 GiBof RAM and you have now 2,5 GiB (from adresses) -> OK
Hope im not confusing with this. Smile
Fri, Jul 2, 2010 at 7:15:32 AM | Revit 2011 upgrade
Bimman
Bimman Avatar
1 Stars: 2 Votes
very good explaination.  i totally see what is going on, thanks for the info.
PWD
Revit MEP 2011 Upgrade from 2010 pricing
Thu, May 20, 2010 at 10:31:17 AM
Revit upgrade files to 2011
Wed, Jul 28, 2010 at 12:23:51 PM
upgrade from 2010 to 2011, good idea for tight schedule?
Mon, Jul 26, 2010 at 5:45:51 PM
UPGRADE QUESTION
Mon, Jun 12, 2006 at 9:03:39 AM
2012 upgrade - missing type marks
Wed, Jul 13, 2011 at 11:12:39 AM
Page generation time: 6.2302
