30 Users Online (28 Members):
Forums >> Revit Building >> Technical Support >> Radial Array in Elevation View
1 Posts No Rating |
Hi Guys, I'm trying to make a dynamic parametric curtain wall panel that consist of 4 triangular glass pieces that can open and close connected to a mechanicaly controled actuator or a spider web connector that i can fully control, but the main issue that im facing is that i can not make a radial array in elevation view of the nested family , so the steps are after making the glass partition parametric i.e(length,width,height,depth) which is all flexing perfectly, i got then to import it in another generic model family as a nested family to then try radial arraying it in elevation view but unfortunately this error message comes up "Element cannot be mirrored or rotated in a manner that changes its angle relative to the ground." so if anyone has a different way on achieving the required result please let me know on how to tackle this issue.Please have a look at the image attached to get an idea of what im trying to make. cheers
Change start and end heights of elements in radial array |
Tue, Sep 20, 2016 at 7:06:49 AM
Radial Array in a Family |
Mon, Apr 11, 2005 at 8:56:12 PM
Radial array in Families |
Tue, May 28, 2013 at 3:04:01 AM
Parametric Radial Array |
Wed, Dec 14, 2011 at 1:39:23 AM
Radial array in families |
Thu, Nov 25, 2004 at 4:30:59 AM
