Forums >> Revit Building >> Technical Support >> Rafter cut different on each side of roof
Fri, May 28, 2010 at 12:46:14 PM | Rafter cut different on each side of roof
aozarski
The rafter cut options ie. plumb, two-cut square, and two-cut plumb are adequate for what I want to do, but I need them to be different on either side of the roof.  I have come up with a few work arounds but they are kind of messy.  Does anyone have any sugguestions? Thanks in advance.
Edited on: Fri, May 28, 2010 at 12:56:13 PM
Sat, May 29, 2010 at 5:14:33 AM | Rafter cut different on each side of roof
4 Stars: 205 Votes
If you create that in one piece you CAN'T, you can create that roof in several parts (roofs) and each part must have different name then you can change individually "The rafter cut options ie. plumb, two-cut square, and two-cut plumb" OR if youwant only one roof, just use the create in-place family to "CUT" with voids what you need....
Tue, Jun 1, 2010 at 11:11:49 AM | Rafter cut different on each side of roof
aozarski
Thanks for responding.  When you say use the create in place family to "CUT" with voids what you need... do you mean create a mass for a roof and then "CUT" with voids or can you "CUT" with voids a roof created with the roof tool.
Tue, Jun 1, 2010 at 12:29:00 PM | Rafter cut different on each side of roof
4 Stars: 205 Votes
"can you "CUT" with voids a roof created with the roof tool." - YES, create IN-PLACE, choose "Roof" category then create voids like you want to cut the roof but don't forget to use the "Cut Geometry" tool...
Can't make a Two Cut - Square rafter cut on a roof
Fri, Jan 14, 2011 at 6:20:30 PM
Custom Rafter Cut
Wed, Jun 12, 2013 at 3:14:38 AM
Change in rafter thickness in roof
Wed, Jan 6, 2010 at 7:28:23 AM
Problem with rafter cut
Sat, Sep 4, 2010 at 3:44:18 AM
Get Roof Soffit To Have Same Rafter Cut As Roof?
Wed, Jul 16, 2014 at 7:37:35 AM
Page generation time: 0.8731
