Forums >> Revit Structure >> Technical Support >> place window in an opening
Wed, May 26, 2010 at 10:09:26 AM | place window in an opening
Daveybdab
Hello
 I am working on a project where i have been drawing an existing facade of an existing building. I drew it by modeling in place, extrucing the wall up one level at a time. I then added openings for windows by creating voids in teh wall. The result has been really nice and shows all the structural elements really well.
I wanted to know if it would now be possible to add windows & frames to the openings so that i can get a render of how the building will look when its complete. I have been looking at the window button in the architectural tab but that doesn't seem to like adding a window into a void. Have attached a pic showing my wall with just the void openings
Any advice would be much appreciated
Wed, May 26, 2010 at 10:23:54 AM | place window in an opening
Remove your void and place your window.  You can turn off the window if you need to just see the hole.
Opening numbers
Mon, Dec 19, 2005 at 3:07:29 AM
Window Head / Opening Cut
Mon, Feb 10, 2014 at 7:30:59 AM
window opening
Mon, Aug 24, 2009 at 8:03:18 AM
new window in demoed opening
Tue, May 13, 2008 at 12:07:18 PM
Slanting Wall vs Window inserts
Tue, Apr 19, 2005 at 7:51:49 AM
Page generation time: 2.9006
