Forums >> Revit Building >> Technical Support >> HATCH PROBLEM
Fri, Sep 30, 2005 at 3:57:11 PM | HATCH PROBLEM
hip36
I have been using a solid black hatch but changing the color in the properties to RBG 192-192-192 to get a screened effect. It seems to have suddenly backfired certain hatches have returned to solid black even though their properties still show the gray color setting. Now 2 hatches side by side with the same properties apear different. I have lost controle. Any help would be appreciated hip36
Sun, Oct 2, 2005 at 6:48:24 PM | RE: HATCH PROBLEM
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Sounds very strange. So they are both the same type filled regions and appear differently?? Sounds like a bug for Autodesk support.
Mon, Oct 3, 2005 at 3:27:27 PM | RE: HATCH PROBLEM
jstewart
We have also been having issues with hatching. When we export elevations to CAD some hatch is missing others are overlapping with differnt hatches and some are the totally wrong hatch. Even though it all looks correct in Revit. I put in a support request to Autodesk and they are working on it now! It is a huge problem for us though becuase you can't even fix it in CAD becuase it does not recognize the hatch.
Control Hatch Display
Tue, Jan 10, 2012 at 10:26:34 AM
HATCH 22- REVIT MODEL HATCH
Fri, May 8, 2015 at 3:01:04 AM
pdf export from revit problem - grey hatch is weird
Fri, Oct 23, 2020 at 6:38:51 AM
How to set the origin for hatch in revit
Fri, Sep 16, 2016 at 3:03:45 PM
Custom hatch of odd tile size
Fri, Jul 20, 2012 at 5:27:57 PM
Page generation time: 0.7329
